What size tire by rim size?
Old 09-18-2009, 11:36 AM
mx_579's Avatar
mx_579 is on a distinguished road
Default What size tire by rim size?
I have done alot of searching and can't figure out what size tire would be right by rim size. Does anyone know if the tire width should be about the same as the rim width? I calculated to find out that 9.5" (the rim width I'm looking at) is 241.3mm. So would I go with a 235 or 245 width tire or is it better to go with a wider or narrower tire? As far as height goes I looked at the stock tire size 235/70-15 and came up with 27.96 O/A height so to switch to 22" rims and keep the O/A height about the same it looks like a 245/30-22 (245*.30*2=+22) will be about the same height with 27.79. I'm sure the larger tire on the stock size will have more "give" so the bigger rim with the tire might end up being a little taller in actual application. Does this sound about right to anyone else?
Edit: I found the info here if anyone else is interested.
wheylo
Tires and Wheels
03-30-2014 04:15 PM
aboll79
Tires and Wheels
01-07-2012 11:28 PM
jcp723
Tires and Wheels
09-30-2008 04:32 PM
blazernate1002
Tires and Wheels
01-03-2006 12:51 PM
demjjm
Tires and Wheels
10-03-2005 04:44 PM
Quick Reply: What size tire by rim size?
