Wheel Spacers 02' 2wd 4 door lifted
Hey y'all, looking for some advice for a set of wheel spacers. My truck is 2wd with a 2" body lift and a 2" suspension lift rolling on 31x1050x15 factory wheels. The tires sit flush with the wheel well, looking from directly in the front or back the tires almost appear stock. I'm looking to make the oversized tires stick out slightly to no longer be flush with the body. Need to know if I can run 2" spacers all around or do I need slightly smaller ones for the front and slightly bigger ones in the back? I will consult my local lift shop but since it's Sunday they are not open and I'm impatient so I figured I could ask you guys. Thanks in advance!
With 2" spacers you'll likely run into rubbing issues on the fenders. Even 1.5" spacers might cause you problems. I'd suggest 1.5" would be a better sized spacer for what you're looking for. As for the front and rear, it's up to you if you want to get the same size front and rear. The rear axle width is slightly narrower than the front setup, so some people get 1" wider rear spacers to even it out.
