will these wheels fit?
Old 10-30-2014, 10:20 AM
DTS77's Avatar
DTS77 is on a distinguished road
Default will these wheels fit?
Hello. Im in the process of lifting my 2005 blazer. I've got a set of tires for it but need a set of rims. The tires are 32" and I want the to stick out about 2" further than stock. Will these fit and will I need spacers?http://m.summitracing.com/parts/brw-909b510540
Old 10-31-2014, 09:23 AM
Jamaroon's Avatar
What size tires? 32x?? Those wheels are too wide for 32x11.5 IMO. They will also stick out 5" further than stock.
How much lift do you have? How much trimming are you prepared to do? Do you offroad? If that wheel was a 15x8 it would fit better. I think you're going to have issues with it otherwise.
Old 10-31-2014, 03:41 PM
El_Beautor's Avatar
32's on a Blazer is doable but not at stock height. If you post up answers to Jamaroon's questions and we can give you some ideas about what you'll need to make it work. I agree with Jamaroon too that a 15x8 rim would work better, especially if you're thinking of offroading.
Old 11-01-2014, 05:34 AM
DTS77's Avatar
I'll definitely be offroading. I decided to go with a 2.5" rough country lift, I'm also looking for a 2" or 3" body lift if anyone has a link to one. And I'm fine with going with smaller rims and I knew if have to trim, I've had a little experience with body work and have a best friend whos a welder. The tires are 32" bfgoodrich mud terrains
Old 11-02-2014, 05:50 AM
LeWhite's Avatar
Will you be upgrading your braking that you will loose from the bigger &heaver rolling stock?
Old 11-06-2014, 05:44 AM
DTS77's Avatar
I'll eventually upgrade things as I go. I work at a Chrysler dealer (I know not gm) and I'll have access to parts cheap so things will be getting replaced and upgraded
xJakeLIKEShisBLAZERx
Tires and Wheels
09-10-2011 12:50 PM
stepjl
Tires and Wheels
07-17-2010 07:32 AM
Cavalier z24
Tires and Wheels
16
03-03-2010 11:11 PM
dbleon
Tires and Wheels
04-09-2008 12:25 AM
wdb4719
Tires and Wheels
02-07-2008 10:16 PM
Quick Reply: will these wheels fit?
