will these wheels fit?
Hello. Im in the process of lifting my 2005 blazer. I've got a set of tires for it but need a set of rims. The tires are 32" and I want the to stick out about 2" further than stock. Will these fit and will I need spacers?http://m.summitracing.com/parts/brw-909b510540
What size tires? 32x?? Those wheels are too wide for 32x11.5 IMO. They will also stick out 5" further than stock.
How much lift do you have? How much trimming are you prepared to do? Do you offroad? If that wheel was a 15x8 it would fit better. I think you're going to have issues with it otherwise.
32's on a Blazer is doable but not at stock height. If you post up answers to Jamaroon's questions and we can give you some ideas about what you'll need to make it work. I agree with Jamaroon too that a 15x8 rim would work better, especially if you're thinking of offroading.
I'll definitely be offroading. I decided to go with a 2.5" rough country lift, I'm also looking for a 2" or 3" body lift if anyone has a link to one. And I'm fine with going with smaller rims and I knew if have to trim, I've had a little experience with body work and have a best friend whos a welder. The tires are 32" bfgoodrich mud terrains
