1st Gen S-series (1983-1994) Tech Discuss 1st generation s-series (1983-1994) general tech topics here.
1989 s10 blazer
Old 08-05-2018, 12:13 PM
Moliver1327 is on a distinguished road
Default 1989 s10 blazer
The front wheels are getting hot and seems like there is dragging happening when Iím driving it, when I got it parked it was smoking and it smelled like the breaks. What could be causing this? Thank you
Old 08-05-2018, 05:00 PM
christine_208 is on a distinguished road
The guide rods for the calipers could be sticking on the calipers so that the pads are always in contact with the rotors.
Old 08-05-2018, 10:48 PM
i took those off and checked them and cleaned them really good, and the breaks are still compressed not allowing the wheel to spin. When I press the break and release it the wheel wonít spin freely then I wait and they will slowly but not all the way release.
Old 08-05-2018, 10:57 PM
I think I've heard of the pistons on the calipers getting stuck. You might need new calipers. How thick are the pads?
Old 08-06-2018, 06:57 AM
that may be it, I heard you can rebuild them but Iíd say it would be better just to replace them as old as they are. As for the pads I guess there standard, I replaced the pads about 5 months ago and it just recently started doing this.
Old 08-06-2018, 12:20 PM
Tom A is on a distinguished road
Is it possible that your brake fluid got contaminated with oil?
Old 08-07-2018, 07:43 AM
error_401 is on a distinguished road
Oil in the brake hydraulics could cause your calipers to stick if the system was filled and bled with it. Some oils may make the rubber gaskets in the system swell.
But normally never heard of that.
Most of the time it is simple corrosion that has corroded the cylinders in the caliper. Once you wear the pads and disc down at some point the brake pistons reach the corroded area and stick. Sometimes (depending on the type of caliper - and the use of the respective guide and manual) the outer dust-rubber boots can be removed and the brake pistons and cylinders are visible.
The brakes must release completely when you release the pedal, else it is a serious issue because the pads will drag.
Replacing the calipers with reman ones is usually the way to go. Depending on how badly damaged, the repair will be out of the scope of a DIY repair.
Old 08-07-2018, 07:48 AM
I once had to fix a truck after the driver topped off the master cylinder with ATF and drove it for a week. Every rubber part in the whole system was swollen to about twice its normal size. It was pretty ugly.
Old 08-07-2018, 12:32 PM
mom going to buy new calipers today and try that and Iíll let you know how that goes! Thank you for the help
suitsmefine
09-08-2009 08:08 AM
dannycam
04-28-2009 09:41 AM
deanosride
03-29-2009 06:17 PM
bigt
02-02-2007 10:17 AM
bruce.mcvicker
04-30-2006 12:06 PM
Quick Reply: 1989 s10 blazer
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
