1993 S10 sensor troubles----can anyone help.
I have a 1993 S10 4.3L z motor. When i ran the codes for my truck i got a 43 code telling me to check the knock sensor circuit. so i replaced the side knock sensor pig tali connector cause it was crack in 4 spots. that didnt help my truck start. Now in gettin codes 33, and 34 for my MAP sensor, and code 22 for my TPS. the thing is i dont know exactly where either of those to are on my motor.
Can any one help? Anyone got pix?
The TPS sensor is on the throttle body while the MAP sensor should be located on the intake manifold.
thanks for that. i changed the map today the computer isnt giving me nemore codes but it still wont start
Why did you replace it? Because of the codes? Did you test the wiring to make sure that it had continuity from point A (the sensor) to point B (the ECM)?
Abutera76
16
07-17-2012 07:28 PM
Abutera76
12-22-2010 05:55 PM
ckevroll
06-14-2009 09:46 AM
hey all, 87' blazer s10 owner here, having a problem. anyone help me? i can post in tech problems fo
blazer_geezer
04-27-2007 01:55 AM
