1994 s10 Blazer CPI Vacuum Help
On a '94, that line that you are holding in the first picture should run down to the evap canister located under the air box. It goes into one side of the 't' pictured in the second picture. The other side of that 't' should go to the branch/check-valve fitting on the side that is perpendicular to the other 4 outlets. From there, the two lines you have probably run to the HVAC and transfer case. One of the other two could possibly run to the cruise (if equiped) and the other is likely just supposed to be plugged.
fslobodecki@yahoo.com
04-15-2011 03:29 PM
uhlhazard
01-04-2011 08:13 PM
94BlazerT
04-13-2010 03:13 PM
sweet-98ta
01-05-2010 12:56 PM
