87 S10 Blazer Lift Gate opening problems
On my 87 Blazer, it has the 2 piece rear opening. Top window opens upward, bottom tail-gate comes down. And at the top of the tail-gate, there is a little black turn **** with 2 arms stinking out, and a key hole in the middle. A couple months ago it worked fine. You put the key in, and turn the black part left, it opens the window, then right helps drop down the tail-gate. Well now, the black part just spins around and doesnt "grab" the key hole like it should. Anyone have/had this problem and know how to fix it?
You have to open up the gate & see the mechanism. Sounds like it's broken & you should be able to find a new one on rockauto.com. Don't forget to look in the main page here for the monthly discount code.
Mine did the same thing once when I turned it too hard one time and "overshot" the internal catch lever thing. I had to remove the inside plastic door panel and some other metal shields to get to the inside of the latch to re-engage the little lever that the black twisty handle engages with.
Does that make any sense?
It is possible however that you simply broke the twisty handle and will need a new one.
Sh*t happens, and nothing lasts forever.
Rock Auto is your best bet for a new one.
GOOD LUCK!
GOOD LUCK!
BigEffingHammer
10-01-2011 06:02 PM
futuredoc
06-03-2011 08:09 PM
JODYM
02-01-2009 12:44 PM
web road runner
11-13-2007 10:15 AM
