88 s10 blazer 4x4 engaging on its own.
Old 08-14-2011, 02:44 PM
Frank A's Avatar
Frank A is on a distinguished road
Default 88 s10 blazer 4x4 engaging on its own.
Im having a problem with the 4x4 trying to engage itself in 2wd, when i slow down and come to a stop.The front axle display light blinks and i can hear the front end trying to engage.This all started when i used the 4x4 and then back to 2wd. Thanks for any suggestions!
Old 08-14-2011, 02:49 PM
Sounds like you have a leaking vacuum switch on the transfer case that is allowing engine vacuum to pull on the front axle engagement actuator when it is in 2HI. The line to the actuator should be vented when in 2HI.
Old 08-14-2011, 03:06 PM
Frank A's Avatar
Thank you for your help!
Old 08-14-2011, 03:08 PM
No problem. Let us know what you find.
Old 08-14-2011, 07:10 PM
Frank A's Avatar
Hello Swartlkk I have a question,im about to take off the vacuum switch and was wondering if the 3 hoses have to go back on the switch the same way?Does the switch know when to pull off each hose?
Old 08-14-2011, 07:14 PM
They have to go back on in the same locations, but the connector that the lines go into should be keyed. They are arranged as follows as viewed looking at the switch itself:
The black rectangle is the 'key' that prevents the installation of the connector onto the switch in the wrong orientation.
Old 08-15-2011, 07:30 PM
Frank A's Avatar
I have a new vacuum switch on order but now my air condioning only works on defrost.I have been reading up on your posts,very informitive!When i get the new switch will it correct the ac control also?Thanks swartlkk!
seriosbrad
11-07-2015 09:08 PM
jersey bob
10-31-2011 07:54 PM
Chevy604
09-05-2011 11:43 AM
jeepetr
07-09-2011 11:58 AM
Kamri_j
04-06-2010 06:59 PM
Quick Reply: 88 s10 blazer 4x4 engaging on its own.
