89 S10 Blazer 4.3 4X4 I cant find Speedo Cable
Old 11-12-2012, 10:43 AM
RexCastle's Avatar
RexCastle is on a distinguished road
Default 89 S10 Blazer 4.3 4X4 I cant find Speedo Cable
I am trying to located where the speedo cable is located under the truck with no avail, does anyone have a photo?
Old 11-12-2012, 11:35 AM
neo71665's Avatar
I think 89 still has cable drive if so:
comes out the drivers side of the t-case, runs under the drivers seat, up the firewall, into the firewall right beside the brake booster.
Old 11-12-2012, 12:41 PM
Diaita's Avatar
Diaita will become famous soon enough
tailhousing of the transfer case(near the rear driveshaft)
Old 11-12-2012, 02:48 PM
Blazin_Jason's Avatar
My 89's are electronic speedo.
Old 11-12-2012, 06:08 PM
neo71665's Avatar
Thanks for clearing that up. I was thinking 90 was the swap year. Honestly 89 is one of the 3 85-93 I haven't owned.....yet.
Old 11-12-2012, 07:10 PM
RexCastle's Avatar
well the problem i am having is speedo and odo are not working but everyhting else in the cluster is. also i have the old style gauges like the 88's not the newer digital
Old 11-12-2012, 08:03 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
is possibly your oil gauge funky and your brake light on? Mine did all that and speedo when my gauge fuse fuse was blown. turned out to be a short in the harness behind the distributor.
Old 11-12-2012, 08:53 PM
RexCastle's Avatar
Oil gauge is fine and no lights on that shouldn't be. I found some old records in the glove box dated back to 2010 and it had the same milage on the receipt that the odo currently reads, so i know the problem has been there at-least 2 years at a min
Old 11-12-2012, 09:00 PM
neo71665's Avatar
Most likely the VSS bad.
And they called analog gauges.
Old 11-12-2012, 09:29 PM
RexCastle's Avatar
Is there only 1?
Quick Reply: 89 S10 Blazer 4.3 4X4 I cant find Speedo Cable
