94 Blazer transfer case
Old 10-30-2005, 08:53 PM
bob2231's Avatar
bob2231 is an unknown quantity at this point
Default 94 Blazer transfer case
I have a 94 Blazer and the transfer case seems to be stuck partially in low range. There's a loud grinding noise, and top speed is about 5. It won't go into high range or 2wd. Is there a way to manually disengage the transfer case ?
Thanks
Old 10-30-2005, 09:04 PM
drkmelvin is an unknown quantity at this point
Default RE: 94 Blazer transfer case
This happened on my 93, but I don't know if they changed the design for the newer bodystyle... under the battery, you will see a round vaccum ball..disconect the main line going to the ball and plug it. This disengages the front diff. Then, take the switch out of the dash, and check for a bad connection. If none of these work for you, it may be a problem with the motor that switches the transfer case between 2 and 4 wheel drive. If you hear grinding, it may be that the motor is stuck between gears. Lightly tap the motor with a hammer while someone pushes the 2wd button at the same time. Give that a try, I hope it helps
Old 10-30-2005, 09:11 PM
bob2231's Avatar
Thanks, it's something to try. If nothing else I need to be able to drive it to a junkyard. When it got to where repairs were a constant thing I kind of gave up on this one. I bought a 2000 Blazer 3 weeks ago.
By the way, the 94 was the last of the old style so your directions are probably fine.
Old 10-30-2005, 09:19 PM
Too bad you are so far away... I would have taken it off your hands...oh well, good luck
Old 11-06-2005, 04:40 PM
bob2231's Avatar
It looks like the problem is the switch. I checked Autozone and discount and they don't carry them.
Flyfishen
06-18-2019 11:22 AM
bensaintonge
12-03-2013 08:14 AM
blackdragon258
10-08-2009 01:23 PM
mab
03-10-2008 10:50 AM
Bomblowski
10-04-2007 07:12 AM
Quick Reply: 94 Blazer transfer case
