94 CMFI Injectors Not Firing
Checked the Shrader valve for Fuel Pressure, Works. Spark, and firing order and timing checked. Car has been sitting for over a year. The injectors will not fire, Checked the power to Spider, w/ BAT ground, and test light works, tested Spider ground to BAT (+) and nothing, it appears that the ECU is not sending the signal for the Spider to operate. Hooking +12v to Spider Positive and temp grounding it, will cause it to work. cranks with starter fluid.
Any suggestions? Aftermarket(new) MSD Coil. Fairely new MSD billet distributor, had to replace the Module for it to spark.
Thanks
Thanks
Martin13
11-15-2013 07:32 AM
creighta
06-12-2010 02:02 PM
Boise LCD
18
05-24-2010 11:14 PM
wayland
12-09-2009 12:38 PM
