'94 s-10 blazer fuel filter replacement question
Another quick question for somebody who has done this before. I got a new fuel filter to replace the old, and know where it is located to replace it.
Is there any thing I must disconnect, like a fuse or relay in order for me to unscrew the filter and not get sprayed by gas from pressure? Will gas run out of the fuel line continuously while the old filter is off? Someone give me instructions, please!
Thanks- Kyle
Thanks- Kyle
You can purge fuel from the fuel nozzle under the hood to relieve pressure. (the thing that looks like an air valve stem at the back/top of the engine)
Don't smoke, wear old clothes and be prepared to spill about a pint of gas.
Just turn your face and loosen, Your only gonna get alittle bit of gas comming out lol
haha. gotcha man, I'm going to do this replacement today.. wish me luck that I don't bend or twist off a fuel line..
That would suck if you did heh, Goodluck!
You could remove the fuel pump fuse while it's running. That'll release the pressure but you're still going to have a little gas in the line.
lennyblazer
53
02-03-2016 01:54 PM
95jblaze
08-27-2011 03:46 PM
2FAST4U
01-06-2006 08:21 AM
