backfiring
Old 04-15-2012, 06:26 PM
Gary99's Avatar
Gary99 is on a distinguished road
Default backfiring
Have a 99 Blazer V6 4x4 and now when I first pull out in the morning I am getting a popping backfiring noise thru the throttle body. The car feels like its being held back then I get this noise a few times. After that the car runs ok.
Any body have any ideas as to what this could be? I could really use the advise
Thanks
Old 04-15-2012, 09:29 PM
50lb_cat's Avatar
Backfiring is usually a timing or ignition problem. You can also try disconnecting the maf sensor to see if it helps, if it does it needs cleaned. Have you done a tune up on it?
mbar
02-13-2010 09:36 AM
Iceman_19
08-26-2009 03:14 PM
chris12001
02-12-2009 11:44 PM
johncagain
05-11-2008 08:30 PM
infamous
01-07-2007 04:18 AM
Quick Reply: backfiring
