can i use these two together w/o probs
Old 12-19-2006, 01:51 PM
skitzobmxr's Avatar
skitzobmxr is an unknown quantity at this point
Default can i use these two together w/o probs
http://www.stylinconcepts.com/parts....tfamilyid/1476
http://www.truckperformance.com/prod...10+Blazer/4.3L
im thinking about buying both of those...there woldnt be a prob if i use them both right?
Old 12-19-2006, 02:19 PM
Chevy Lover's Avatar
Default RE: can i use these two together w/o probs
Nope, it says with the air filter lid.. Fits Models With Round Factory Filter Only (TBI)
Old 12-19-2006, 02:59 PM
skitzobmxr's Avatar
right, but the FIPK for the 91 is a round filter, it looks like the same thing except is more open then the factory........ one which one would be better if i just bought one
Old 12-19-2006, 06:51 PM
The first one would probably allow more air flow.
Old 12-20-2006, 04:08 AM
I would get the OEM replacement filter, that has enough air flow. Your engine does have the TBI unit and the computer may not be able to handle the air coming from the air lid. The TBI is designed to with a closed lid for a reason if you remove the metal area directly above the TBI it will affect air flow into the TBI and cause problems. That EXTREME Lid is designed for a large bore carburated engine not a stock V6.
Old 12-20-2006, 05:07 PM
skitzobmxr's Avatar
arite thx...wuddya think about a throttle body spacer
Old 12-20-2006, 05:22 PM
nofear17bmx is an unknown quantity at this point
What does a TB space do anyways. What do you benifit from it?
brendan127
12-11-2011 10:08 PM
cochran07
03-07-2011 04:36 PM
JeremyNYR
04-11-2010 10:45 PM
The_Beast
03-27-2010 06:32 PM
Quick Reply: can i use these two together w/o probs
