egr valve clean
what exactly are the symptoms of a 'dirty' egr valve? i 'cleaned mine out today' with throttle body cleaner. i've heard mention of soaking them over night. is the screen on the gasket overly beneficial?
any feedback would be sweet. ps: it was removed with 10mm socket. used extension on driver side bolt. only have to detach air hose and corresponding wires. |
'94 T10 with a cpi engine.
Symptoms - code 32 or 34 (cant remember which) in the engine light... Stalling out at lights and easily restarting... surging at operating temperature.
A stuck open egr is basically a huge vacuum leak. Horrible idle, poor acceleration, but drive-able at speed. The screened gasket is a must!!!! Chunks of carbon from the intake is what sticks in them and holds the little plunger open. If you go back with a regular gasket, you will more than likely have the same problem again very soon.
If an EGR valve was stuck open would it make a loud annoying noise?
Originally Posted by GMC_Jimmy_13
(Post 577202)
