93 S10 blazer problems
while i was driving my 93 s10 blazer it just stalled out and I waited a couple of minutes and tried to start again and it started for 15 seconds. I changed the distributor and it started again but than it died again. any help will be greatly appreciated.
Try using a scan tool to see what codes come up. Most auto parts stores will let you use them, at least here they do. Depending on what your results are, have you checked your battery connections and grounds?
check your fuel pump for the proper pressure at the check valve.thats what mine was doing when it was going to die
I'd guess fuel filter. Maybe 95% plugged. Probably seeps enough gas thru it to run for 10-15sec.
94BlazerGirl
08-28-2014 06:14 PM
Luke92S10Blazer
02-06-2010 04:24 PM
upblazer95
04-04-2009 08:27 PM
SPL2Alan
11-28-2006 11:31 AM
