Front Dual Caliper modification done
Old 07-22-2017, 08:43 PM
mr.vls's Avatar
mr.vls will become famous soon enough
Default Front Dual Caliper modification done
Today I finished my front dual piston caliper upgrade on my 89 S15 Jimmy 2DR, 2WD. I pulled a steering knuckle with rotors, backing plates, calipers, hoses, hose bracket, hubs and all mounting hardware for $90 at a you pull it junkyard. I did end up buying new hub bearings from Detroit Axle, New AC Delco brake pads and new AC Delco duralast professional rotors (Non friction areas are painted). In the process I noticed my passenger side lower ball joint was bad so I installed new Moog upper and lower ball joints on both sides. I did not take any pics because it is so hot in southern Mississippi I was trying to get as much done in the shortest time possible. Test drive went great. The vehicle stops on a dime. This is on top of the other mods I have done in the last few months. I recently converted the rear drum to disc brakes and installed a G80 differential and at the same time installed new carrier bearings and axle bearings with a new ring & pinion gear set.
Old 07-24-2017, 02:02 PM
El_Beautor's Avatar
Nice work!
Old 07-24-2017, 06:13 PM
mr.vls's Avatar
Thanks
Old 07-27-2017, 08:45 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
Yea,did it to my old blazer i had. It didnt really "stop faster" but it was more of a consistent stop. I didnt have to struggle as much on the pedal.
Old 11-11-2017, 01:10 AM
Lefet's Avatar
Lefet is on a distinguished road
I haven't seen much about the rear brake conversion, that's something I'd like to do to mine. How did you do it and how long did it take?
Old 11-11-2017, 02:20 AM
mr.vls's Avatar
Old 11-11-2017, 02:38 AM
Lefet's Avatar
Thanks!!!
jimspahr@msn.com
16
07-02-2022 07:46 PM
quinn1991
Tires and Wheels
12-28-2008 02:41 AM
paulf707
06-30-2008 08:25 PM
Newbeme
02-08-2008 10:42 PM
prototype80
07-13-2006 08:19 PM
Quick Reply: Front Dual Caliper modification done
