Hydrolock question
Old 01-29-2009, 06:50 AM
v8dan's Avatar
v8dan is an unknown quantity at this point
Default Hydrolock question
Hello I'm Dan and a new guy to the forum and have question I hope it is in the right place, I have an 84 first gen that i put a 94 5.7 TPI motor in,everything went great untill I tried to start it and it hydrolocked on me, #6 cylinder filled up with gas, luck was with me and it just blew the nosecone off my starter, but after putting in a new starter it still does it, I have put in new injectors and had a new harness made from chevythunder.com.What would cause this ? I pulled the vac line off the fuel pressure reglator and there was gas in the line and also my plenum,is the regulator bad or do I have it hooked to the wrong vac port? This being a batch fire system I would think all the cylinders on that side to be full since it fires all of one bank at a time, not just the number 6 cylinder. This is a speed density system with the 1227730 ecm, I have had it running for about an hour and it ran rich but after the hydrolock I had to change the starter and flexplate and oil and have not had it running since it locks up right away. sorry for the long post but I am lost here any help would be great. Thanks
Old 01-29-2009, 08:07 AM
Default RE: Hydrolock question
If you have fuel in the vacuum line, that would indicate that the FPR is gone. Which cylinder is the vacuum line port over top of?
Old 01-29-2009, 08:54 AM
v8dan's Avatar
There are two right above number 6 & 8 one is supposed to be for the MAP and the other for the FPR
Old 01-29-2009, 08:58 AM
Yep so that explains it. There should be no fuel in the FPR vacuum line. Replace the FPR and that should cure your problem.
Old 01-29-2009, 09:55 AM
v8dan's Avatar
Thank you sir I will tear it apart and try to find a replacemnet for it
Old 01-29-2009, 09:56 AM
ORIGINAL: v8dan
test
test what?
Old 01-29-2009, 10:01 AM
v8dan's Avatar
sorry having a hard time submitting replys to my post
TDawg
01-09-2011 02:53 AM
98Ltblazer
04-11-2010 11:34 PM
Numba1Sean
05-06-2009 11:48 PM
redfan13
03-11-2008 09:37 PM
Chadoo951
05-06-2007 07:01 PM
Quick Reply: Hydrolock question
