ideling and starting issues
ok well this is an on going problem i have had, when the truck runs for a while and im sitting in traffic or at a long light it will start to idel like ****, until i start driving than it smooths out. along with that problem its been struggling to start, it will turn over a longer than normal eventually it will start. the plugs and wires have recently been changed, and maybe a year ago the whole fuel system was replaced, tank, pump lines injector. At this point im thinking it has to be fuel
any suggestions ?
thanks
Eric
any suggestions ?
thanks
Eric
What is it you are driving?
yeah that might help lol
a 94 s10 blazer
someone said the EGR might be hung up and to remove it and spray it down ..
a 94 s10 blazer
anyone have any pics or diagrams where the EGR is located .. ? hopefully ill get it done tonight
Front of the motor, below the throttle body (where the intake hose attaches). Looks kinda like a soda can.
You'll need at least 9" of extensions and a 10 mm socket (and stick a little piece of paper towel in it so the bolt sticks better) - for the driver's side bolt. For the passenger-side bolt, you'll need a 10 mm wrench; a ratcheting wrench makes it easier.
You'll also need a replacement gasket. Get the one from the HELP! section - it's screened.
necropenetrator
12-27-2008 05:58 PM
Sprocket
03-20-2008 09:39 PM
kpiper
12-15-2007 06:28 PM
dragonsdeath
10-07-2006 01:08 AM
