Idle issue, delayed downshifts
Old 05-26-2013, 11:06 AM
jfrust64's Avatar
jfrust64 is on a distinguished road
Default Idle issue, delayed downshifts
Happy Memorial Day all and thank you vets!
I have a 94 S-10 W code and it has started to idle higher than normal and will cruise at 40 mph without touching the gas. The tranny won't kick down to low until the truck is almost stopped. Once the rpms drop the SES light comes on until you hit the gas again.
I replaced the cap, rotor, plugs and wires along with an oil change but I'm thinking the TPS or IAC but was looking for some advice before I hit the parts store.
Thanks in advance for any help/direction
Old 05-31-2013, 08:14 PM
go-part's Avatar
Former Sponsor
go-part is on a distinguished road
Old 08-06-2013, 07:55 PM
jfrust64's Avatar
So we replaced the throttle position sensor, the idle air sensor and the ECM and no change. We just had it out and the exhaust manifolds on both cylinder banks are glowing red. I don't think it should be running this hot. Could a bad cat create the excessive heat and the idle issue?
Any advice would be appreciated
Old 08-06-2013, 08:14 PM
97cherryblazer's Avatar
97cherryblazer will become famous soon enough97cherryblazer will become famous soon enough
A bad cat can cause those symptoms, yes. If you have the ability to take the temperature of the cat, let the engine idle for a while then see if the cat has a significant temperature change from the front half to the back half.
Old 08-07-2013, 09:37 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
vacuum leak, running too lean. Also check ign timing. Make sure throttle isn't hanging open
tallhorseman
05-03-2012 05:45 PM
91blazerlifted
03-06-2012 04:09 PM
old 5k0ol
06-11-2011 10:45 AM
dimone545
09-21-2010 12:08 PM
fuzzball447
07-29-2007 05:25 AM
Quick Reply: Idle issue, delayed downshifts
