idles high, shifts hard
Old 03-20-2011, 01:53 AM
dmc919's Avatar
dmc919 is an unknown quantity at this point
Default idles high, shifts hard
the other day my blazer started idling really high can be going 30mph and let go of gas stays a constant 30, and shifts really hard and late in every gear, have to give it alot of gas for it to shift. I have checked the idle air control valve and its moving back and forth when i turn the key on, also took egr valve off, its clean no carbon. no check engine light either, i'm lost anyone got an idea?
Old 03-22-2011, 10:57 PM
dmc919's Avatar
is there a sensor that would effect the transmission and idle speed?
Old 03-23-2011, 10:00 AM
Not really related, but a vacuum leak could possibly skew the MAP readings which may cause a firmer shift.
You need to check over all of the intake gasket surfaces & vacuum lines for signs of a vacuum leak and correct any leaks that you find. Clean the throttle body and make sure that the throttle isn't getting stuck open.
bdk
12-23-2011 10:33 AM
TheNasty0ne
12-17-2010 09:59 PM
Dfretty
09-09-2010 09:54 PM
hubert hefner
05-12-2010 05:55 PM
bearsfangb1
03-24-2010 07:04 AM
Quick Reply: idles high, shifts hard
