Installed amp wires, now ful pump doesn't run unless jumped!?
I just got done running amp wires from the battery and the stereo back thru the passenger side. Now the fuel pump isn't working... Is there anything I might of messed up?
Power wire from battery on passenger side thru the antenna groomet at floor of passenger at firewall. Then back onder the carpet. I pulled the trim strip from the floor board on the passenger side where the door goes to conceal the wires. Also, I ran the 2 rca wires and amp lead from the radio to beheind the glove box and then down along with the power wire.
The fuel pump does run when I jump it in the engine bay.
Remedy: ECM B 10 AMP Fuse. Thank god! I Was Trippin!
JohnBarJB
09-28-2020 07:34 PM
hypertek
26
03-03-2013 04:58 PM
SDadam
08-09-2010 09:58 PM
rogggg1020
09-24-2008 06:53 AM
