LOTS OF GAS IN MY OIL ????
Old 12-24-2005, 03:45 AM
charrliy525's Avatar
charrliy525 is an unknown quantity at this point
Default RE: LOTS OF GAS IN MY OIL ????
LM`MF`AO,I knew all about go-cart motors,2cycle dirtbike motors,and V8 350`s and ford inline 6`s,mainly in old novas and old F100`s by age 16 (all for orange grove and field trashen till they hit the scrap yard)at 16 got a license and my 1st 4 bangen mazda,built swimming pools like i still do and ragged the hell out of that little thing until 1 day i kept hearen a whining,squeeling noise,knew nothing of T.B. carbs,carrier bearings,cat converters,or all the other crap they came up with after 1982.inline 6 300 or v8-350 and 2barrel or 4barrel carbs i could build sleeping,so my smartass boss say`s-ITS THE MUFFLER BEARING!MY gulluble a..,young dumb full of .......goes to discount auto asking for it,luckily the old man tom knew me so well since i was 12 w/t all my other junkers,could not beleive i fell for that with what i knew then,longer story short-i got lucky i knew them n they knew me and the joke ended there,ive sent at least 4 or 5 young bucks looking for 1 since though and they get sent to napa,autozone,discopunt,and hell,even to junk yards ive seen being told to pull the cat. before some 1 fills them in on its a joke.my prob was the carrier bearing whitch was a sinch.ANYWAY-IM A FRKN STORY TELLER AS U CAN SEE,BK 2 THE MAIN ISSUE AT HAND.
Old 12-24-2005, 03:59 AM
You would think a plug or 2 would foul or no compression cuase rings are shot out whitch i thought was the only way gas could fill the block is through the piston and rings.But like i said,Drain it,refill it with new oil,Turn key,Dont even stop n wait,TURN N START AND IT PURRRRRRRRRRRRRRRRRRRRRRRRRRRSSSSSSSSSSSSSSSSSSSSS SSSSSSSSSSS,Will purr like some of my G.F.`s and run like a raped ape,till you turn it off,i probably drove it for who knows how long till 1 day at a store a guy says-MAN YOUR SHI.`S TAKEN A **** ON MY PARKING LOT,i had horrible gas mileage i noticed about 2 weeks prior to that day,now i know where it went-lmao-never blew a rod,still runs great,no knocks or nothing with 168,463.7 miles on her,i have never done anything to it-no plugs wires caps rotors never cleaned the injectors change the oil every time i get a hair up my butt,run all 87 gases,had her since 24K,im a firm beleiver that sometimes the gunk holds the worn out in place.now my 2000 blazer 2 w/d 4.3 just hit 65K and is a piece of crap,and it has oil done at or be4 3K,changed all fluids and trans filter every 15K,and at 65K it needs the valves adjusted bad,idles crazy some times,just did a new ultifunction switch in the columb last week whitch they wanted 260 buxs for but i got it used for 50 from a buddy,tac n reverse lights quit around 49K and im sick of looking for the short,door pins 3 times now-winder motor 3 times now,crap,crap,crap,the newer the worser,my old lady from 94 is still running good with gas for oil-lmao,,anyway y`all get my point,and yes go ahead and b... about the long typen segments,these car things right now got me a little ticked,its 2am and i think im going to pull the ol`girl in and tear her down and see what i find,,let y`all know in a few hours.
Old 01-11-2006, 12:11 PM
i just posted a new post,i`m fixen to start tearen this blazer down and tommorrow im going to buy the nut kit,regulater,etc;...that was mentioned with the pics on how to do all that on my origanal post.but i`m just asking 1 more time,is this top section with the injector,fuel lines,regulator,etc;..the only way fuel can fill your block up to the top of the dipstick tube along with the 5 quarts of oil thats suppose to be in it,??? i`m just asking 1 last time so i dont go spending 350.00+ and it still fills up the block with gas afterwards.and also-even full of gas mixed with the oil in the block it runs fine,no fouled plugs,or loss of compression/power,but as soon as i noticed this problem,i only run it to move it around the yard and it starts as soon as u turn the key-no hesitation.let me know if you have any other things to check where the fuel can fill the block.
Old 01-11-2006, 12:42 PM
There isn't any other way for fuel to get into the engine other than through those lines.
Old 01-11-2006, 06:13 PM
93LT is an unknown quantity at this point
ORIGINAL: swartlkk
Well, other than pulling the duct work off the upper plenum and letting it rip.
Old 01-11-2006, 06:29 PM
Yeah, obviously, but I was speaking more on a running, fully assembled, engine.
crd_ba
12-11-2012 08:07 AM
Chukhed
07-04-2010 08:17 PM
93 s10 justin
03-05-2010 04:09 PM
jimhens82
12-23-2009 04:50 AM
Deezy Steez
11-03-2009 06:03 PM
Quick Reply: LOTS OF GAS IN MY OIL ????
