New blazer and some swap questions
Old 11-19-2009, 02:44 AM
JDogIII's Avatar
JDogIII is on a distinguished road
Default New blazer and some swap questions
Just bought myself a 1991 S10 blazer 4x4 4.3l that has Edelbrock shorty headers, Smog pump delete, magna flow exhaust and hypertech chip. I had some questions about doing a head swap, intake manifold and a cam.
I have a set of 95/96? vortec heads -need to check the numbers to double check- and was wondering what manifold i needed. I have seen some stuff for the Edelbrock 2114 manifold w/ an adapter plate. But was looking at the Edelbrock 2111 on their website and not sure if that will work.
Also looking at cams, should i go with a stock 95/96 cam or go with an aftermarket on?
I've got a lot brewing in my head and could use some insight
Im looking to stick with TBI and dont plan on swapping to carb any time soon.
Old 11-19-2009, 04:58 AM
neo71665's Avatar
The stock intake aint that bad compared to most aftermarket ones I've seen, the smog pump only takes like 1 maybe 2 hp to turn, exhaust is in the eye of the beholder, the stock manifolds are supposed to be good to like 3-400 HP, and mass produced computer chips are junk.
About the only real gain from the parts you suggested is swapping to the newer heads.
Old 11-19-2009, 06:16 AM
96+ heads will have vertical intake bolt orientation while the 95-older heads had the intake bolts perpendicular to the gasket surface. That is the only thing you'll have to be sure of.
the 96+ heads are marginally better than the earlier ones.
Old 11-19-2009, 11:21 AM
JDogIII's Avatar
The smog pump and other stuff i "suggested" is a list of stuff that has Already been done to the truck.
Thank you swartlkk i'll go double check the heads today
Old 11-19-2009, 11:25 AM
86Blazer327's Avatar
86Blazer327 is an unknown quantity at this point
Headers will add HP any day of the week and twice on sunday , How much hp is the question. Every engine I ever stuck em on you can at least tell a difference.
I realize they are already on there, Im just adding my 2 pennys
Old 11-19-2009, 04:39 PM
neo71665's Avatar
99% of the time I will agree whole heart but its been proven the stock manifolds on a 4.3 flow fine until you start getting to the 3-400 HP range. Most of these tests were done on syclone and typhoons so I don't know crap about 2nd gens but from my understanding the manifolds didn't change much. I doubt anybody on here are pumping out those numbers so most the time headers are just for show.
qcblazer
07-07-2013 06:43 AM
DannyBanana
Lifting Tech
09-25-2011 07:05 PM
djtwray
06-28-2009 02:57 PM
Quick Reply: New blazer and some swap questions
