oil filter problems
I've had to stab a filter now and then but I've never done in the end of the filter. The reason you stab it in the side rather than the end is so you can then use the handle of the screwdriver to turn the filter.
Not sure you can even get access to the side and then be able to turn it from the looks of the picture so a filter wrench might be your best bet.
fixed my problen
I was able to get the filter off by hammering a screwdriver threw the filter accesed from the engine compartment! Its all good now thank you everyone! My blazer is npw running i just need a new muffler but besides that all is good! I had to rerun vacume lines tune up that carb and reset the timing on the distributor.
cahlersmeyer
23
11-10-2011 09:23 PM
subarugt06
03-06-2011 11:21 AM
shooter2499
02-04-2008 09:23 PM
