parking lights & dimmer switch buzzing
I have a 1991 GMC Jimmy i noticed when i turn on the parking brake lights when the dimmer switch is at its fullest brightness the door buzzer starts buzzing. when i turn the dimmer down it stops buzzing.
I checked the fuses all the fuses are good, could be some sort of ground issue or is it a issue with the ignition switch. idk
any one know where the buzzer is located under the dash?
I want to remove the buzzer, since its annoying and useless.
I have the same exact problem! Just started today. Did you solve it yet? If anyone knows how to fix this I'd really like to know because it's really annoying. I know this thread is 3 months old but I just wanted to let you know someone else has the same problem and see if you have a solution.
FIXED! i removed the buzzer from under the drivers side dash.
Just follow your ears and its located atop around the hood release cable handle.
It was a black box 3 in x 3in x1 and just pulls out toward the front of the vehicle.
84_K5
12-21-2009 12:16 PM
