play in steering
play in steering
I did body work on my truck where it sat in the shop for 3 months and I drove it home and the ignition cylinder gave out on my so I replaced it the other day but now I have a lot of play in the steering wheel about 2" on the left and 4" on the right. I was wondering is there anything I could have taken apart when replacing the ignition cylinder that might have not got put back together right that would cause that much play or is it something else?
well I haven't had time to check any of that yet but I would assume all my steering and suspension parts should still be good as I just replaced all of it last year because a lot of it was going bad I replaced it all with Moog parts. I was just assuming it might be something to do with the steering wheel not being put back together correctly.
NOTE: The factory bushing setup has rivots (4) holding the bushing in place. You'll have to grind those off to replace the bushing, and use hardware to put it back together.
Especially when you got a lift, and 33x12.5s... Anyhow, another possibility would be the pitman arm? I'm leaning more towards the bushing though.
Kojak
01-23-2008 06:28 PM
