Question about door removal
Old 01-23-2006, 06:44 PM
camohog1's Avatar
camohog1 is an unknown quantity at this point
Default Question about door removal
I was wondering if anyone knows how to get the window crank off the door so that the door panel can be removed. Thanks for the help guys.
Old 01-23-2006, 07:32 PM
Default RE: Question about door removal
I don't know whether or not it would help to know the year/model of window crank you've got or not, but many times, they have a plastic snap ring inside that you just have to pry the crank off the splined shaft. They make special removal tools like this one -
Window Handle Removal Tool
to pry them off without damaging the door trim panel.
Old 01-23-2006, 08:15 PM
camohog1's Avatar
it is a 1991 S-10 4.3 liter 2 door. It has manual locks and obviously manuel windows also.
Old 01-24-2006, 03:32 AM
blazin97's Avatar
blazin97 is on a distinguished road
take a straight screw driver and push the door pannel back around the window crank and you should see a u shaped ring that goes around the window crank. You have to either pull it out with needle nose pliers(if you can fit them in there) or with a screw driver. then just pull the handle off, be careful not to loose that clip you have to put it back on the crank or it will keep falling off.
Nate_The_Great
01-01-2012 11:23 AM
wolv2401
02-09-2008 07:36 PM
blazerscooby
02-19-2006 11:11 PM
pusher_sr
01-24-2006 07:58 PM
john65807
01-07-2006 11:31 AM
Quick Reply: Question about door removal
