R/R Oil Pan Gasket without removing Engine
Old 01-11-2019, 09:29 PM
mr.vls's Avatar
mr.vls will become famous soon enough
Default R/R Oil Pan Gasket without removing Engine
I managed to replace the oil pan gasket without removing the engine. But it was a real PIA. Steps: Drain Oil and remove oil filter, Jacked up vehicle for clearance to work under the car, Removed Y- Pipe from exhaust manifolds, Removed flywheel cover. Removed engine mount bolts, Removed Transmission Mount Bolts, Raised engine with engine hoist, Removed Oil Pan Bolts, Dropped Oil Pan, Spent about an 1 to 2 hours on my back trying to fish the oil pan gasket under the pick up tube and to the other side, I than spent about 3 hours getting all of the oil pan bolts in and the new gasket to properly line up to the oil pan.
mr.vls
01-08-2019 05:58 PM
mr.vls
06-29-2018 03:07 PM
Johnson
11-16-2017 04:58 PM
snobrd
06-24-2011 10:28 PM
bobditts
06-18-2009 06:38 AM
Quick Reply: R/R Oil Pan Gasket without removing Engine
