Stripped Caliper Guide Bolt Fix
I bought my truck with stripped steering knuckles where the caliper bolt screws into. You can use an oversized bolt as a temporary fix, but eventually the threads will not longer hold.
Searched everywhere for the correct helicoil kit for the 1st Gen trucks. I installed this weekend in about 15 minutes.
Heli-Coil 55287 7/16-20 Kit
This is the correct kit. You will also need a 29/64 bit to drill the hole clean.
The kit does also NOT come with a tap handle but I screwed it in with a pair of adjustable vise grips.
softail88
09-15-2011 06:55 PM
pmezo
04-18-2010 05:13 PM
ComputerNerdBD
14
11-27-2009 06:08 PM
