tbi spacer?
Old 03-22-2008, 10:13 PM
92 blazin's Avatar
92 blazin is an unknown quantity at this point
Default tbi spacer?
i have a 92 s10 blazer qitha 4.3l non vortec and was wondering if a tbi spacer really inproves gas millage and performance and is it worth getting one?
Old 03-23-2008, 04:08 AM
neo71665's Avatar
Default RE: tbi spacer?
simple, no, no, and no
Old 03-23-2008, 06:35 PM
The fundamental theory behind the use of a throttle body spacer is to lengthen the intake runner to shift the torque curve lower in the RPM range. An engine with a torque peak high in the RPM range can benefit from a throttle body spacer. If an engine already has its torque peak low in the RPM range, or has an almost flat torque curve, there is no benefit. All of the 4.3L v6 engines fall into the later category.
I had ones CNC cut for my old 3.5L Intrepid and gained a solid 2mpg with them. This engine had very little low RPM torque and showed decent benefits from the addition of the spacers.
Old 03-23-2008, 06:59 PM
strong blazer is an unknown quantity at this point
well i have one on my 91 4dr 4.3 and my gas mpg didnt really change but i did get little extra thrust when i installed it with after market breatherlike this one so it could suck more air in to the throttle body my throttle bodspacer is by airaide
deathman
08-14-2011 11:25 PM
87fullsizeblazer888
02-24-2011 12:38 PM
maverik78
Performance & Brainstorming
04-11-2010 10:05 PM
94Blaze
Engine & Internal
01-05-2005 09:59 PM
Quick Reply: tbi spacer?
