trans trouble
trans trouble
1994, 4.3engine. will not shift.no1st, 3rd, overdrive.2nd is all there is when in drive or overdrive or 1st, stays in second. also speedometer goes to 70mph when you stop, even when vehicle is shut off.I have never had a problem no slipage (nothing). any ideas
RE: trans trouble
I guess i should add that reverse works fine and it goes into park. so i dont think the linkage is mess up.
RE: trans trouble
might be an issue with your valve body or a bad filter.
What color is the trany fluid? and does it smell burnt?
RE: trans trouble
color red. does not smell. I changed every 25000. due agin in 7000
RE: trans trouble
Have you checked your fuses? I recall my Dad having the same issue with his 93. A fuse was blown and the trans is shifted by the ECM past the 1-2 shift. Korey.
RE: trans trouble
i have not checked fuses but i will tomorrow.
RE: trans trouble
No experience with the 94, but I know that the tranny did the same thing (stay in 2nd) and I had no spedo and my ABS went nuts when my VSS (Vehicle Speed Sensor) went out in the '95. VSS may be something to look into. A lot changed between 1994 and 1995, so someone more familiar with the earlier trucks may say otherwise.
-Hal
-Hal
RE: trans trouble
I was thinkin the same thing about the VSS
RE: trans trouble
I just wanted to thank all that help.
It was the VSS (vehicle speed sensor).
auto zone wanted 57.00 pruchased from the dealer for 42.00 imagine that, has to be a first.
Greg
Greg
grounded87
07-01-2011 11:22 AM
