What water pump to buy? Blazer 1993
Not to confuse anyone .... just an FYI:
All 4.3 water pumps will fit all 4.3 engines from '87 to '05 - the TWO differences between 1st gen and 2nd gen (yours is a 1st gen)are the pulley (one is a V-belt, and one is serpentine(you have serpentine) and the fan clutch style (one mounts with 4 bolts(you have the 4 bolt style), and the other, just one large nut in the center). There is also a V- belt and serpentine style that both use the 4-bolt mounting of the fan clutch - that setup would be easier to swap back and forth. The different style pulleys change the distance from the engine the belt runs, so changing from one to the other is not easily possible.
All the bolt holes are the same on the blocks of 1st & second gen engines - only difference is 1st gen is SAE threads, 2nd gen is metric. Everything will bolt right up from one to the other - you just need the hardware .. and on a second gen you;d have to remove a stud or 2.
Again, just FYI for those who want to know. Buying the correct pump for your year-model is the easiest way to ensure a bolt-on-and-go setup with no modification.
Well, am kind of lost already. More I read and look more confusing the damn thing is.
Different brands, different numbers, the pulling or pushing type - on man.
I just uploaded some photos of my pump to: Blazer - Blazer
Hope it will be clear enough to see what exactly I have. I don't have that hexa bolt like some have.
Sure would like to finish this ordeal.....
At this time it doesn't matter if they ship to Europe or not - I just need the exact pump.
TIA
TIA
countryguy1713
06-16-2008 06:53 PM
jes9999
01-01-2007 06:12 PM
