Wire up push button start w/switch
Old 12-24-2007, 05:53 PM
88jimmah's Avatar
88jimmah is an unknown quantity at this point
Default Wire up push button start w/switch
Recently my ignition became stuck in the "on" possition, and will not turn off.
I want to just bypass the ignition and hook up a toggle switch for the accessories and a push button for the starter.
I have never done this before and was hoping someone here has and could tell me what I need to do (in detail, if it isnt to much trouble), or could point me to a place that has the information I am looking for.
Thanks in advanced for any help/information!
Old 12-25-2007, 08:45 PM
hillbillyinOhio's Avatar
Default RE: Wire up push button start w/switch
read this post, then ask if you have more questions.
http://www.the12volt.com/installbay/...h+button+start
Old 12-26-2007, 05:29 PM
DetroitMuscle is an unknown quantity at this point
That might be helpful for a general overview of how to do it but it is a dodge and you got a chevy
Old 12-26-2007, 05:33 PM
what does it matter what car it is. Same thing for 99 percent of cars on the road.
Make sure you know what you are talking about before you make comments. lol
Old 12-28-2007, 08:54 PM
88jimmah's Avatar
Well I was mainly looking for a how-to on how to do it to my jimmy I have the general idea on what needs to be done but the problem is I am not sure which wires or how to get to said wires.
My guess is that I have to take the steering wheel off and remove the old ignition which would reveal the wires needed.
Old 12-28-2007, 09:03 PM
Blazin_Jason's Avatar
Remove the panels under the wheel so that you can have access to the main plugs on the column. Here is some information on what wires are there. It might help to loosen the 2 15mm (I think) nuts that hold the column up to get to the plugs.
Old 12-28-2007, 10:18 PM
88jimmah's Avatar
Cool, thanks!
So this is what im guessing...
On the toggle switch I will have the following:
SIDEA: Accessory Orange wire
SIDEB:Constant 12V Red wire
And the following hooked to the push button:
SIDEA: Starter Yellow wire
SIDEA:Ignition Pink wire
I am not sure if I need to have a ground wire...and if so where does it need to be
Old 12-28-2007, 10:52 PM
I'm trying to seach and see what to do. I would think that the ignition is going to have to be on with the toggle switch. The push button should only activate the starter.
Old 12-28-2007, 11:15 PM
88jimmah's Avatar
Yea I think you are correct about that...when I first typed that reply I had that on the toggle switch but changed it.
Old 12-28-2007, 11:21 PM
Couple sites here. 1 & 2
I'm thinking something like this. I've never done this before.
On the toggle switch:
SIDEA: Accessory & Ignition Orange wire & Pink wire
So when the switch is on, contact is made to activate and turn on the accessory and ignition.
So when the switch is pressed it cranks the starter.
I don't think you will need to ground. Now go out and try it =)
Quick Reply: Wire up push button start w/switch
