-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   '03 4.3 and tranny in a 93?? (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/03-4-3-tranny-93-a-19783/)
JoPre 04-15-2008 03:28 PM
as the title states. would a 4.3 andthe occumpining(not sureif i spelled that right ha)tranny out of a 2003 s10 fit into my 1993 blazer which also came with a 4.3? both trannys are auto. i know there are some differences. but im just wondering what would have to be done to do this.
- thanks in advance - Jordan
94blueknight 04-16-2008 02:37 PM
RE: '03 4.3 and tranny in a 93??
i dont think it will. i remember seeing somewhere that they r mounted to the engine differently so u would also need the motor. i'm not a 100% on this but i'm sure swartlkk will comment on this.
swartlkk 04-16-2008 03:08 PM
Different bell housing, case, and overall length and depending on the transmission in your truck (fully electronic 4L60E vs semi-electronic 4L60).
JoPre 04-16-2008 06:18 PM
well im talkin about putting the whole thing; engine and tranny in. and yes im prettysuremy blazer has the 4L60E stock.
swartlkk 04-16-2008 08:12 PM
The overall length of the transmission is different from the one peice main case to the 2 peice main case. And good luck with the electronics from the '03. That is going to be one major headache as the newer PCMs want to communicate with every other module in the truck (the original '03 stuff). If you do not have everything, you will likely run into problems.
Now, maybe you were thinking of putting your top end (heads up) onto the '03 block and use the transmission etc. You'd likely need to measure and modify your driveshaft to fit appropriately.
JoPre 04-17-2008 04:21 PM
ok so basically alot of work and not really worth it. thanks
