1993 4.3 cpi starting problems
Old Sep 29, 2011 | 07:16 PM
freez's Avatar
freez is on a distinguished road
Default 1993 4.3 cpi starting problems
hey all , new to the forum , I am looking for a little help.
I have a 1993 s10 blazer 4X4 with the 4.3 vortec with the CPI fuel injection on it.
My girl was driving one day and it came to a stop, would not start again. Had car towed home . I had plenty of spark so next went to fuel. I noticed the fuel pump would not come on when I turned the key so figured it was fuel pump . Dropped the tank put a new fuel pump and now the fuel pump will come on when the key is turned but it still will not start. I can pour fuel into the intake and the car will run until fuel i poured in is burnt up . Car still will not run.
I can push down on the fuel pressure relief valve and it will spray fuel, so I know I am getting fuel to the intake but I don't think it is spraying through the fuel injectors , well haha obviously it is not spraying through the injectors the dang thing will not run. The relay is working as the pump will come on for 2 seconds and I believe the oil pressure switch is working because when I pour fuel into the intake and it runs, as it is about to die I can hear the fuel pump working.
any input or help would be greatly appreciated
Old Sep 29, 2011 | 07:26 PM
xgiovannix12's Avatar
fuel diagnosis with a pressure gauge. Fuel might be coming out of the check valve but might not be enough PSI to make the injectors spray correctly
https://blazerforum.com/forum/tech-a...agnosis-23038/
Old Sep 30, 2011 | 12:14 AM
just plain lucky's Avatar
just plain lucky is on a distinguished road
What type of fuel pump you put in?? Please don't say from auto zone delphi the way to go...
Old Sep 30, 2011 | 05:28 AM
freez's Avatar
ya man ,I believe the girlfriend got the pump from autozone....now let me ask this , are the pumps the same for both the cpi and tpi models , i know the tpi run at a lower pressure
Old Sep 30, 2011 | 01:21 PM
No there not the same tbi requires 15 psi cpi requires 60 psi
also i wouldn't be going with any after market pumps (autozone)
Id be going with delco or delphi
Old Sep 30, 2011 | 04:31 PM
freez's Avatar
just did a little looking on autozone website and that's exactly what happened.They gave us the TPI fuel pump and not the CPI fuel pump . Thanks guys for the input and will get back here to post up the end results. Got to drop the dang tank for a third time .
Old Sep 30, 2011 | 04:54 PM
if you go with an after market product be prepared to drop it a 4th
just warning you
Old Nov 28, 2011 | 08:07 AM
midnightrider's Avatar
midnightrider is on a distinguished road
I'm sure you've thought of this buuuuuut....You might want to clean that tank out while you've got it dropped, helps to extend the life of your pump, that's always a bonus !!!!!
J
Old Nov 28, 2011 | 01:26 PM
chris015's Avatar
I hope you didnt swap it out with another aftermarket pump...
you might be thinking "oh these guys are just wanting it done right,but its my money etc"
We are speaking from how many times WE have dropped the tank to replace the pumps.there is a quality difference. between that and these blazers being picky as hell,buy a ac delco or delphi.
Old Nov 30, 2011 | 02:11 PM
I agree with you guys totally....sftermsrket is not the way to go when shopping for FP's.......although, I had a Walbro, super efficient....
J
1993 S10 BLAZER 4X4 CPI
Sep 16, 2012 11:28 AM
catdrugn
Oct 10, 2009 06:50 PM
Mo Lee
Oct 21, 2008 06:07 AM
cannibal440
Mar 3, 2008 01:43 PM
rlt7272
Mar 5, 2007 09:06 AM
