1993 s-10 blazer brakes
My 93 blazer front drivers side brake will not release after applying brake, replaced calipers, same problem. passenger side working ok. thanks for your help, phil
RE: 1993 s-10 blazer brakes
I would suspect a collapsed brake line. With age, the lining of a flexible brake line will degrade and swell, cutting off flow. This can cause the caliper to hang up as high pressure brake fluid makes its way through, but the return, low pressure flow is restricted.
| All times are GMT -5. The time now is 02:52 AM. |
