-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   1993 S10 sensor troubles----can anyone help. (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/1993-s10-sensor-troubles-can-anyone-help-42551/)
beavis735 Mar 24, 2010 06:22 PM
I have a 1993 S10 4.3L z motor. When i ran the codes for my truck i got a 43 code telling me to check the knock sensor circuit. so i replaced the side knock sensor pig tali connector cause it was crack in 4 spots. that didnt help my truck start. Now in gettin codes 33, and 34 for my MAP sensor, and code 22 for my TPS. the thing is i dont know exactly where either of those to are on my motor.
Can any one help? Anyone got pix?
swartlkk Mar 24, 2010 08:52 PM
The TPS sensor is on the throttle body while the MAP sensor should be located on the intake manifold.
beavis735 Mar 25, 2010 02:34 PM
thanks for that. i changed the map today the computer isnt giving me nemore codes but it still wont start
swartlkk Mar 25, 2010 02:43 PM
Why did you replace it? Because of the codes? Did you test the wiring to make sure that it had continuity from point A (the sensor) to point B (the ECM)?
