1994 Chevy s10 4.3 TBI won’t start when warm
My truck starts up fine no problem while cold, but as soon as it gets warm and I try to start it again it just cracks over and over and usually takes me around 5-10 minutes to get it started again. It only does this if I’m let’s say running errands and I’m in and out, but it’d it’s site for a while then it will start back up fine
Here’s what I have changed: distributor cap and rotor iac rebuilt TBI O2 fuel pump |
When it does not start - do you have ignition?
My 94 did this due to a broken ignition control module ICM on the distributor. It would even run fine when warm unless shut-down, then it would not restart until cooled down. |
I done some more digging and doubt out it was the ignition coil, replaced it with an ac delco and now it fires right up
Originally Posted by Charrisps6
(Post 720750)
A coil is one of the spare parts I always keep in the truck, so once I figured out it had no spark going to the distributor I just pluged in my spare and I put the coil on the intake until I got home and bolted it in. |
| All times are GMT -5. The time now is 07:21 PM. |
