-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   4.3 high idle how do you adjust it? (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/4-3-high-idle-how-do-you-adjust-38603/)
midnightryder 12-29-2009 02:35 PM
92 s-10 blazer 4.3 high idle how do you adjust this?
swartlkk 12-29-2009 02:40 PM
CPI or TBI?
Either way, it is controlled by the ECU via the IAC valve. Base idle air setting can be changed, but first you have to verify that the IAC valve is doing its job and that you do not have other contributing factors (namely vacuum leaks).
midnightryder 12-29-2009 02:43 PM
it is the non vortec motor. it doesnt appear to have any vaccum leaks i did look for that. what is the iac valve an how do you check if its doing its job?
