4.3 z motor stalling after warmed up
Old May 10, 2012 | 08:29 PM
dhmiller80's Avatar
dhmiller80 is on a distinguished road
Default 4.3 z motor stalling after warmed up
my 92 blazer stalls and wont refire unless i used some ether sprayed into the tbi. new fuel pump, lines, filter, just bought a fuel pressure regulator rebuild kit. not installed yet. any answers of why this may happen? its a 1992 sblazer 4.3 z motor, 5 speed 2 door, 4x4, black. just thought i'd throw all specifics in there.
Old May 10, 2012 | 10:56 PM
mr.vls's Avatar
1. Fuel Pressure TBI-11PSI, 2. Idle Air Control Valve. 3. Faulty Injector. 4. Temp Sendor for ECU out of spec. 5 Leaking EGR Valve. 6. Throttle Position Sensor. 7. O2 Sensor. Any one of these items can cause problems you are describing.
Old May 11, 2012 | 07:30 AM
Mag-300's Avatar
Mag-300 is on a distinguished road
One thing to check FIRST.
Your ECMB fuse.The connections that the fuse plug into work loose and can cause the fuse to disconnect and reconnect after it cools.I actually had mine on fire several time and it never blew the 10 amp fuse.Melted the fuse and plastic box but didn't pop.
gabeld2
Dec 28, 2012 06:56 AM
PseudoKirby
Oct 10, 2011 09:41 AM
camocarrier
Sep 4, 2011 10:17 AM
epederson
Dec 7, 2010 06:34 AM
summer
May 3, 2010 08:10 AM
