4WD Issues, please help!
Old 08-11-2010, 07:18 PM
DATEGGY39's Avatar
DATEGGY39 is on a distinguished road
Default 4WD Issues, please help!
1994 GMC Jimmy SLE
4wd doesnt work correctly, it clicks and clanks, and jumps forward like it is going in to 4 wheel drive but no power goes to the front, the front drive shaft even has power to it, i layed under it while my buddy inched forward and the drive shaft spins... any ideas? i would like to handle this myself if possible
Old 08-11-2010, 07:30 PM
There is a wealth of information just a search away. The Tech Article (DIY) section is a good place to start. Have a read through this, then search a bit more once you get some ideas:
4x4 No Worky.... Maybe this will help....
Old 08-18-2010, 03:31 PM
radiokid's Avatar
radiokid is on a distinguished road
sounds like the vacuum hub actuator located under the battery on the fender.
Inspect the rubber on the unit and if it is cracked most likely thats your issue.
Also inspect and replace any bad or broken vacuum lines.
Old 08-24-2010, 01:27 PM
94s10blazin's Avatar
94s10blazin is on a distinguished road
Default no 4x4 for a while now
removed front drive shaft 2 to 2.5 years ago . had no front pull, vacuum actuator still worked , transfer case worked , front grinding when in 2 wheel . i removed drive shaft and grinding stopped. haven't really done anything since, figured i would have to drop the front axle. bought front axle and saved the gears . anyone know what to do?
parks336
12-01-2023 12:34 PM
kyknight2001
06-04-2011 10:06 PM
cruukedeye
06-04-2011 06:49 PM
TrailBlazen
03-25-2009 06:52 PM
rogggg1020
11-11-2008 08:05 AM
Quick Reply: 4WD Issues, please help!
