'86 S10 Blazer
Hey everyone I'm new to this but I need some help. I have a 1986 S10 blazer with a 2.8 in it.The fuel pump went out on it and I don't know how to replace it.Could someone please tell me what to do. Thank you so much.
RE: '86 S10 Blazer
The fuel pump is attached to the fuel sending unit, which is located in the fuel tank. Which means that the fuel tank has to be dropped/removed in order to replace the pump assembly. That's providing it is TBI and not carb'd.
RE: '86 S10 Blazer
THANK YOU Blazin_Jason It is a TBI so I guess I'll have to drop the tank.Oh well I guess it's time to get dirty.LOL!
RE: '86 S10 Blazer
Yup, you're gonna get dirty! If you can, try to get as much fuel out of the tank as you can!
RE: '86 S10 Blazer
Thanks everybody........you guys have been a lot help![sm=groupwave.gif]
RE: '86 S10 Blazer
Couple things to add. Be carefull removing/replacing the fuel pump and sending unit. I've read that if it get's banged too much it won't be accurate anymore. Meaning that the gag gauge will read funky. Also while it's out I would clean it out a little bit. Throw some kerosene in there with a couple nuts and shake it around. Also watch out for any pinholes in the tank. When I took the tank out of my 85 blazer I found a few holes around the tank straps.
RE: '86 S10 Blazer
Thanks for the info Blazin_Jason. It definitely came in handy.
| All times are GMT -5. The time now is 07:15 PM. |
