-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   '87 S-10 Blazer - Anyone familiar with dash wiring? (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/87-s-10-blazer-anyone-familiar-dash-wiring-74976/)
WD4JKH 11-04-2012 04:16 PM
I 'm apparently having an intermittent issue with the wiring in my dash. It seems to be losing the ground connection for the dash circuits including the cigarette lighter. I will notice the dash voltmeter reading low and if I push on the dash it will jump back up to normal. I also see changes in the temp and fuel gauges when this happens and also the backlight is affected.
If I use a meter and check from a solid ground like a seat bolt to the ground side of the cigarette lighter I can see a voltage difference where it should be zero.
My question before I start tearing the dash apart is has anyone dealt with this before and where might I find the connection for grounding the dash circuit?
Thanks - David
abig84 11-04-2012 07:36 PM
on my 83 it was at the very bottom left corner of the dash, kinda right above the ebrake pedal. it will be one of those 1/4 inch sized screws facing upwards with a small wire going to it. so just lay on the floor and look up by the pedal hopefully you see it
i hope that fixes it i spent days tracing the wires and eventually found it.
neo71665 11-04-2012 07:51 PM
There is more than one on the FI models. Wanna say the one by the e-brake is most common problem one since its the lowest. If you look from the engine side of the firewall all the sharp pointy knuckle skinners poing through are a screw and a good place to chase the head on the interior side. Every one won't be a ground but a good number are.
WD4JKH 11-05-2012 06:35 PM
Y'all both nailed it. I checked this evening before I ran some errands and found the wire above the ebrake pedal was loose as a goose. I tightened it up and everything seems to work just fine now - thanks a bunch since it saved me a lot of time and effort.
FYI about what I do with my Blazer, here are some posts from another forum I follow:
From 4 years ago, '1987 S-10 Blazer with 3 Radios' and the recent update 'Added more toys to my 'retro' Blazer set-up.
Thanks again for the help!
David
abig84 11-06-2012 07:03 PM
no problem, like i said i ended up tearing apart my dash a few times and spent quite a few hours searching for that stupid wire
