88 blazer broke door handle
passengerside door handle is not broke .but the lever to the linkage is broke.hpoe you know what i mean any videos of this replacement availeble ? the inside door handle works.
No Video but you will need do remove the door panel, Two nuts will hold the door handle on. There is a linkage from the door handle to the lock assembly. There should be two access holes to access the nuts. Most likely your door handle will need to be replaced. (They brake and are not repairable) Help mate makes replacement door handles.
Its super simple, mr.vls covered it, Just pull off the door handle, There will be 2 self tapping nuts (so dont over tighten when installing)
To get the rod off the door handle, its just held in with a plastic clip. unlock the clip, lower it down and the rod will come right out. I got mine from orielly for I believe 20 bucks. |
thanks so much for quick reply. i'm going to do this repair .il be closing this post as of now .
