89 starter help needed!!!! please help!!!
Old Feb 25, 2005 | 04:02 PM
blazin4eva's Avatar
blazin4eva is an unknown quantity at this point
Default 89 starter help needed!!!! please help!!!
i'm replacing the starter in my 89 s-10 blazer and the (+) battery cable terminal (the end that goes on the starter) broke off (i'm guessing from being bent???) but i need help on what to do for this...is a do it yourself job or does it have to go to a shop??? any help will be greatly appreciated....thanks in advance.
Old Feb 26, 2005 | 02:29 AM
bufferpad's Avatar
bufferpad is an unknown quantity at this point
Default RE: 89 starter help needed!!!! please help!!!
you can either go to your local parts store and buy a clamp fitting to replace the one you broke, or buy a new cable. Either way, you should be able to do it yourself
Old Feb 26, 2005 | 12:04 PM
Fat Timmy's Avatar
Fat Timmy is an unknown quantity at this point
I would buy a whole new cable if you want quality work. If the cable broke, it's probably corroded through more than just the place that it broke. Its not an expensive fix, but i think it would be well worth replacing the whole cable. You'll feel better about it that way too.
jdmmario
Oct 25, 2014 06:25 PM
hzl6cm
Jan 15, 2013 08:36 AM
codybarber1315
Aug 6, 2010 07:32 PM
rogggg1020
Nov 11, 2008 08:05 AM
jdblazer
Jun 1, 2007 09:27 AM
