-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   '90 S10 Blazer automatic not shifting gears (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/90-s10-blazer-automatic-not-shifting-gears-95784/)
luiguiv 11-24-2017 12:58 AM
Hey guys,
I hope you're doing great. I have a 1990 4.3L S10 Blazer, automatic 4x4.
The car was working relatively fine until today. Started the car, drove it for 5 miles and made a stop for a few minutes, just to find out it was not shifting gears any more.
The car stays in 1 gear despite switching overDrive, Drive, 2 or 1. Reverse is working. If i give it more gas it revs pretty quick. It has never had any slips between gears.
Can this be a shift solenoid problem or maybe a blown fuse for the solenoids (i am not sure if this older models had a fuse for this solenoids)? I am affraid the transmission could be dead :confused:
I am not experienced with automatic transmissions; had to research and read a lot on this today due to this problem to get a better idea on what to expect when taking it to a repair shop.
Any information or tips you can provide are much appreciated.
Thanks in advance,
silentjonsays 12-03-2017 04:24 AM
Did you check the fluid?
abig84 12-04-2017 11:15 AM
if the speedometer isnt working it could be the vehicle speed sensor.
my 93 has some goofy issue where it keeps popping the ign/gau fuse, but when it does that it goes into 2nd gear until the fuse is replaced
