91 blazer stalls after long idle
I recently moved from Calif to Michigan my blazer runs fine, but after a long idle it coughs and hesitates when accelerating. Runs fine unless I sit at idle after warmed up i.e. drive thru at McDonalds, bank ect. So where do I start?
RE: 91 blazer stalls after long idle
Possibly exhaust system, or EGR system. Mine codes the o2 sensor running lean after a long idle. Do you get any codes?
Sounds as though it is loading up with fuel... Have you checked for a fuel leak around the injectors (this is a TBI motor correct?)? How about a vacuum leak at the base of the throttle body? Possibly a partially clogged IAC passage/valve (I think the TBI motors had an IAC valve anyway)?
I'll throw 20 bucks on the timing being off a tad, Had the same problem with my 86 s10 pickup. Get a mechanic to throw a timing light on it
| All times are GMT -5. The time now is 09:05 AM. |
