-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   91 s10 blazer no crank no start (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/91-s10-blazer-no-crank-no-start-95711/)
Lunchbox12387 Nov 11, 2017 07:03 AM
Hey Guys,
I recently picked up a 91 s10 blazer with the 4.3 motor in it. The truck has 98k on it and runs perfect. Yesterday I went to the gas station turned the truck off. I turned it back on and headed to my next destination. I turned the truck off went inside and when I came back out the truck won't crank. I turn the key and nothing happens. My lights come on and my radio turns off when I try to start. I have no clicking or anything. Battery volts are sitting at 12.3 static and 11.7 with key on. I tried to get a jump yesterday and nothing worked. I tried to start in neutral and again no crank. I do notice dash lights get a little dim while I turn key but other than that headlights are bright as well as interior lights. Any ideas what could be wrong?!
richphotos Nov 11, 2017 08:40 AM
No crank with power, check the starter.
Lunchbox12387 Nov 11, 2017 09:06 AM
Even with starting and driving fine for 2 starts before hand? Then the last trip just decided to stop working? I will try and give it some love taps and see if that helps. I was thinking neutral safety switch too. Any validity behind that?
newguy Nov 11, 2017 11:32 AM
check all the connections, make sure they`re clean, battery, alt. starter, grounds etc.
newguy Nov 11, 2017 11:33 AM
dont think its the safety switch
and yes it will quit that fast
Lunchbox12387 Nov 11, 2017 12:42 PM
Okay I just jumped out my starter solenoid. When I connect it manually it will whind but not engage so I'm guessing the starter shaft itself is stuck?
Lunchbox12387 Nov 11, 2017 09:33 PM
I'm guessing ignition switch. I have no power to the crank fuse and no power to the starter while cranking
newguy Nov 11, 2017 10:53 PM
you have power to the lights when you turn rhe key, not the ignition switch
Lunchbox12387 Nov 12, 2017 08:45 AM
Correct. Everything works. Lights do not dim while I try and start
Lunchbox12387 Nov 13, 2017 03:28 AM
Fixed. Ignition switch was the problem
